Hi,
I just replaced the water pump and some of the seals (the ones I could safely remove). I say that because the engine has quite a bit of corrosion externally (probably from salt water) and I'm afraid of removing some things with fear of breaking them. Either way, I've got the new pump installed and the drive shaft is installed but will not engage the prop shaft at all. I've turned them both trying to get the splines to match but with no luck. The shaft feels like its bottomed out inside the housing but does not engage.
Any tips or suggestions on how I can get this together correctly?
Thank you
Thank you
