aquatone282
- Aug 15, 2008
- 7
Hi,
I am getting nothing when I turn my ignition switch on - no accessory power and nothing at the motor when I turn to the starting position.
I have confirmed the following with a volt/ohmmeter:
What is confusing me is the switch passing continuity checks but not voltage checks. Is this an indication the switch is bad, or is it more likely something else in the circuit is the cause?
Thanks for any suggestions you might have.
Jim
*B=battery, S=start, C=choke, A=accessory
- Battery is fully charged - bilge pump on separate circuit runs fine
- 12 volts is present at the B* terminal on the switch.
- The kill switch and neutral switch are both good
- When disconnected, the switch passes continuity checks between the B and S terminals, the B and A terminals, and the B and C terminals when the switch is put in the appropriate position for each.
- When connected, there is NO voltage between the B and S terminals when the switch is in the starting position. There is NO voltage present between the B and C terminals when the switch is pushed in.
- There is only 5 volts present at the A terminal when the switch is on the ON position
Jim
