The boat is a 1989 18ft.wellcraft with a built in plastic gas tank. The gas line and antisiphon valve was replaced and the tank was cleaned and drained. The engine is a 2001 150h.p. johnson ocean pro.My question is this, each time I pour fuel into the tank the engine starts right up, afterwards however 5 minutes into running she stalls and it takes some time to restart. Once started after this point she runs great until the next gas fill.The symptoms occur all over again each time. I am placing 10-15 gallons at a time and the tank stays 3/4 filled.Could this be coincidence or is there a possible pressure loss when the gas cap is removed?Thankyou Andy
