Hi all,
My sons have had the Evinrude 15hp out the end of last summer a couple of times but the water pump wasn't pumping as it should of been. The water just dribbled out of the pea hole. I'm just now finding this out.:grumpy:
I have installed a new water pump and now the water comes out as it should. But....
It smokes pretty good in the 30 gallon test bucket, and I'm wondering if there was some kind of damage they did with the water pump not pumping as it should?
I need to also say that it seems to run just fine, starts right up, after a couple of pulls or so on the rope. I should also say that I'm using the same gas that they used the end of last summer, no telling what the fuel to oil ratio would be.
Thanks!!!
RoReRi
Thanks!!!
RoReRi
