rodpaulrod
- Jun 2, 2013
- 27
I have a question. I forgot this engine has a thermostat to it. Now i start the engine and let it run a little while and it turn off because i do see any water coming out the hose that connects to the engine and points out to the water behind the engine. There use to be water coming out of this hose. I got the water pump working 60 HP Evinrude model: E60ELCSR cooling issueimages here . But there's no water coming out the little hose which, looks like it 3/16 inch thick . I think some people call the telltale hose. So what temperature does the engine need to be so that water will come out that hose so that the thermostat will open?
