I've got two Johnson Seahorse's: a 1964 and a 1967. The '64 is an automatic, the '67 is a manual. Both run, but the '64 is stuck in forward.
Question #1: Can I swap out the top ends? The '67 overheated and has a scored cylinder, so I'm thinking the top end is toast.
Question #2: Is it more feasable (by feasable, I mean both less expensive and more likey to to fix the problem) to repair the bad lower end on the '64 instead of doing the top end swap?
I'm new to boating (so forgive me if my nomenclature is off), but I've got 12+ years as a GM master mechanic, so I know my way arround the toolbox just fine. Before I go all crazy with diagnosing or parts swapping, I thought I'd ask for some advice.
Stephen
Seattle, WA
Stephen
Seattle, WA
