I need help.. I bought a 1968 33 hp johnson motor and im trying now to find out if the water pump is good or not before i go put in water or not... I cant find anywhere online where the water discharge portal holes are suppose to be located on the lower unit to know if everything is working properly or not.. I have the propeller and all in a large bucket filled with water but when i crank it up i dont see water shooting out anywhere?? is the hole around the prop area or is it suppose to be coming out somewhere else?? can somebody please help.. thanks
