help power pack 3 info, 1972 johnson 65 hp
mbromaghim
I think my power pack is bad, I removed the black/yellow wire from power pack terminal #6, still no spark, I check with an ohm meter and terminal #6 without the wire attached is grounded out...does this sound logical that the power pack is shorted to ground? Thanks in advance, Mike
boobie
Re: help power pack 3 info, 1972 johnson 65 hp
Reverse the ohm meter leads once and see what you get.
