carsronnie
- Jun 2, 2013
- 3
after much research,i have come to the conclusion that my motor has a dealer installed fuel pump that replaced an older style 2 line fuel tank with a single line fuel tank. it is mounted to the motor with 2 screws with a hole between them for the crankcase pulse. there are only 2 lines;in and out. there doesn't seem to be a repair kit for these? I see many sierra brand pumps that appear to mount the same way but have 3 hose connections on them. can someone recommend the right pump and what the connections are for?
