brownning375
- Jun 7, 2013
- 2
I have a 1992 Johnson 120 that sometimes does not want to go in gear, if you move the prop a little it slides right in. We unhooked the cables to make sure that was not the problem, but we were not that luck. It seems it is lockling up on the motor side. When it locks up we cannot shift it by hand, but the strange thing is if you leave it and try it again it will go into gear.
I am wondering if it is a shift linkage issue, or is it a more serious lower end problem? It will work fine shifting back and forth several times, than all of a sudden it does not want to shift. I am at my wits end with this motor.
Thanks.
Rob.
Thanks.
Rob.
