wildcaughtbass
- Jun 6, 2013
- 14
Hooked the car battery straight to the starter and the bendix is slipping to make contact with the flywheel. The bendix gear is worn down to a 25 degree angle. When it does grab the flywheel the starter moves it for about one piston crank then sits on the next and only gives a little hum. When the starter is disconnected it makes a loud barking noise. Pistons have been lubed and I'm not sure how the compression should feel, but it definitely has plenty. I can pull it about two revolutions with a rope, but I have a herniated disc in my back and can't give it my all.
