marcusknight
- Mar 5, 2010
- 156
I have a 1979 70hp Johnson and I am curious if this is supposed to happen. My engine runs and operates well but more often than not when I start it (especially when its warm), it will run for a few seconds and then quit. In order to avoid this, I have to use the neutral throttle lever to give it extra gas. Once I shift it into gear, it seems fine. Is this normal for a two cycle engine or should I have the carbs and fuel system cleaned?
