awakeatground0
- Jun 5, 2013
- 21
I have yet to not get my 72 65hp johnson started but most of the time it is stubborn. When i choke the motor it will not start at all and just floods the carbs to the point where they are dripping fuel from each intake. To get it started i have to leave it un-choked with the throttle plates about half open(when it starts, rpms are around 3000). When motor is started, i drive it for a while to warm it up, then i begin to lower the rpms and start to try and tune each carb starting with the center carb. I can get the rpms(under load) down to about 1200 before the motor wants to stall. When the motor does stall, i have trouble getting it started. I have to back out the needles on each carb and once again un-choked start the motor at half throttle(give or take). When i pull the plugs they are fouled badly. One time i had to pull the plugs and clean them just to get back to the dock.
Things to know: I have pulled each carb and cleaned them( removed some gunk from idle jets and some oil deposits from main jets)
The motor will bog down at WOT from time to time, in this case, i put in neutral and rev a few times, and then off she goes with no bogging.
I switched spark plugs from the kind that you gap to the kind that are gapless(I believe this is the reason for fouling at low rpms however i still had issues with the motor bogging at WOT with both plugs)
I am running 87 octane with 50:1 mix and starbrite star tron enzyme fuel treatment.
After running motor at WOT for 15 - 20 minutes, motor is lupe warm to the touch, definately not overheating, but seems to be a little cool for those kinds of operating conditions maybe? I can put my hand anywhere on the motor and leave it there without flinching.
I think that is all, any advice would be greatly appreciated. Thanks
