I have recently purchased a new to me boat. I am excited to have it and think my problems are hopefully something small. The engine is missing on one cylinder and it isn't charging the battery. I have the factory service manual for the engine and just have begun to start with the trouble shooting. I have approached these as two seperate issues.
On the cylinder that isn't firing, it the one the on the port side bottom of the V4 engine. I swapped the coil with the cylinder above, the spark plug wire as well. Using a timing light I verified that that coil is not firing, where as all the others are fine. I have ordered a power pack that should be here in a few days. I hope that I have correctly Identified the part that needs the replacement to fix this. I am posting about this problem hoping to get some feedback if I am going in the right direction.
On the not charging I have checked the resistance on the coil plug to verify that none of the leads have grounded out, and they appear to be fine, no ground. I have not ordered a rectifier yet because I am still not sure which part to order.
Also, with it not firing on one cylinder could this all be caused by the stator? I have a couple days and can send the power pack back for a refund, any ideas would be very helpful.
