HELP!
I bought a new to me boat and was taking the motor out for a test... about the third time I'd had it out since I bought it. Ran about an hour this way and that way, and suddenly one of the six cylinders quits working. I motor back and think that I will start simple, so I change the spark plugs. Seems a good place to start, right?
Well, the next time out, it seems just fine. Yeah! I fixed it and it wasn't anything bad.
However, the next time out, I notice an irregular miss at high RPM and then turn around and head back and notice that it's running quite poorly by the time I get all the way back. I pull the plugs again and two of the plugs now have no gap in them. It's like the piston pushed it shut?
There isn't any vibration, the compression is fine. The ignition seems to be working just fine. What the heck can cause the spark plugs to do that, without having any other impact on the engine? I'm afraid to take it out again until I figure this out. I don't want to just "hope" it won't happen again, which is what my local mechanic suggested.
Thanks for any help!!!!
