Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
electric starter button for 1973 25hp Evinrude
  • electric starter button for 1973 25hp Evinrude
    I have a 1973 25hp evinrude with an electric starter. The starter button is located forward of the gear shifter on the side of the motor housing. The rubber top of the button has rotted and fallen off. I can still crank it, but I have to use a screwdriver to connect the two contacts. Can anyone tell me where I can find a replacement button?
    Thanks
    Re: electric starter button for 1973 25hp Evinrude
    Post a model #.
    • #3
      If your starter button is like mine on a 77 15hp you can get the rubber covered push button 60 amp switch at Auto Zone or ORielly's for about $15 bucks. Mine was a perfect fit and works really well. Good luck.
