Daniel Merritt
- Sep 13, 2012
- 29
Hello, Well a couple of months ago I put new coils, condensers, points plugs and wires. After getting it all back together and on the water it runs great at idle or trolling speed, it doesn't miss a beat but it doesn't get up to full throttle or even close.. I tied it up to the dock and took the motor cover off to inspect, it appears the shifter leaver is not out enough for the link & stop to advance past to get to full throttle.. Also the roller is only making it halfway up the throttle cam and not reaching max throttle? Is there a chance I didn't connect the stator base properly after I re-wired it? Someone told me the timing is not advancing correct?
Any ideas?
Any ideas?
