Re: power pack bench test.
i blew it .....booo .. one of the wires shorted out some where l think blew either a triac , or thyristor , or the MOSFET Transistor one of these iam not sure witch is used in power pack , i have a very good idea, I think that the power coming from the stator which is AC volts goes through a MOSFET TRANSISTOR first , i just have to try & work out the N P N , configure ration , once i get that done i can then put AC power through it , then its just a matter of working out to get the pulse voltage , which is very low , thats why i gonna use a AA battery by using this battery will be the same as having continuous low voltage supply , the magnetic field around the hall sensor supply current to the sensor , the line in the magnate breaks the current every time it passes this crates the pulse & spark ,and if there was no line there will be a constant current going through the spark plug , this is what made me think to use the AA battery any way something to keep me thinking
