Hi Everyone,
I hope everyone has had a great start to boating season.
I have a 2000, 50 HP Johnson, about 2 years ago I replaced the primer solenoid, and it seemed like that was the issue and it worked fine all last season. This year while getting the boat ready, I noticed the primer solenoid wasn't working with the key again.
Is there anything that could be causing me to blow out primer solenoid?
I would like to note that I noticed that some starting on my outboard under the cover and some corrosion on the bottom spark plug.
I can start the boat by flipping the red switch, but if I can avoid it I would rather not have to open the motor cover every time.
Thanks and have a great day.
Regards
Harry
Regards
Harry
