rogerrabbitis
- May 25, 2003
- 69
I just got a 1990 90hp Evinrude and this has happened 2 times now. First time out had issues with battery and starting got running and everything runs good did a few slow speed runs around 3000rpm but when went back for a full throttle run around 5000rpm just stopped and could not get it to turn over it was like battery was dead. Thought battery issue so bought new battery like 800 cranking amps...started fine went out did a slow speed run around 3000rpm and battery showing around the 14 volts and then went for a full Throttle run around 5000rpm and just died a few seconds in and again not able to turn over with battery acting like was dead. Had booster pack on me this time had to choke and prime it to get it to start and slowly made it back to dock. Any ideas.?? I am thinking 2 issues Fuel delivery at high speed and possibly a battery drain.?? battery was fully charged each time I started and voltage showing 12 but when trying to start going down to 8 or lower. thanks for your help.
