Slab Squathrust
- Oct 10, 2012
- 7
So I have a small 6hp evinrude outboard. The issue is that it cannot run without the choke on. The thing starts up easily on the first or second pull. I can run at all throttle positions as long as the choke is on. When I drop the choke, there is a slight burst of power but then the engine sputters and dies unless the choke is reapplied. I did a quick clean of the carb which allowed me to start it. (It wasn't even starting before.) I assume I missed something. Any ideas or suggestions would be appreciated.
