Re: 99 Evinrude 50 hp 4 stroke water pump failure
No more pieces, flushed it both ways up and down, with the thermostat out and the lower unit off, could not find pressure relief valve/ housing using the illustrated parts diagram on the Evinrude site or my book, replaced water pump and plugged inlet plate on bottom of fin and used muffs on the side inlets, engine runs fine and does not over heat ( with muffs on), However what I did find while running is a lot of water coming out the rear of the mid case housing at the shifter shaft adjustment point, dropped lower unit again, pressurized lower unit with water, there is none coming out around the bottom of the pump, the top pump to shaft seal looked and felt good when the housing was off and the seal retaining spring is in place, the water outlet grommet to inlet water pipe has no tears and felt like it had a good seal, and the water inlet tube was in the pump grommet, Got burnt by that many years ago. Lower unit is off at present. Water is trickling out the tell tale hole when running, Any Ideas, and thanks for the help. I'm going to check the inlet tube for holes tomorrow, anything is possible.
