Got info on removal of vro system, think im up to it. Believe the old fuel pump needs replacing, is it the same type as in use with vro? and is the "diaphragm" portion of pump separate or is it the only pump? Is this something a guy can do on his own or got to pay the mechanic?? It is a 50 hp on pontoon in water.Thanks
