I recently bought a 1967 evinrude fisherman 6hp, used it once and almost got stuck on the lake. It ran great getting out there but to get back to shore I had to play with the choke to keep it going. I replaced the gas/oil 50:1 mix and took apart the carb to give it a quick clean. Upon further inspection I realized that the throttle had no effect on how high or low the engine rev'd. It starts great but dies shortly after if you aren't constantly adjusting the choke.
Has anyone else had this issue? If it is the throttle am I looking at an expensive repair?
