I have 1989 Johnson 90HP Tracker Pro Series.
I did a compression check today, although it had not been started since last summer, and the motor is new to me.
The numbers came out all around 75+/- a few lbs on all four.
Its a little cold blooded, but once warmed up runs well and starts right up......I sprayed Evinrude Tuner spray into the intakes for a bit and it was putting out a ton of smoke and still seemed to after I was done for some time, so I shut it down for now.
I am wondering if anyone can comment on an assessment of this motor and what else I can do or not.
Thanks
Thanks
