OptsyEagle
- Sep 13, 2006
- 1,356
OK, so I am cleaning my carb. All is going well. I have my high speed jet out about 1 turn from gently seated and I have come to a silly problem. My carb has the knobs for both high and slow speed adjust on the slow speed needle. Behind the knobs is a metal bar that connects the high speed knob to the high speed jet, below it. In cleaning the carb I disconnected the bar from the plastic piece on the slow speed jet and left the bar dangling on the high speed jet, since it seemed difficult to remove and it didn't seem necessary.
Now I have noticed that with the bar dangling on the jet, it will not fully turn in since the bar gets stopped by the bottom pan of the motor. So my question is. Does this bar pull out of the metal piece that is connected to the high speed jet. It seems to be sealed in tight with some plastic and I don't want to break it. The other option is a screw that is in the end of the high speed jet that can be used to turn it from the outside of the motor. The problem here is that it is very tight and I don't want to hurt this needle. It is currently in the jet and cannot be unscrewed out due to my problem above ... without removeing the carb from the motor again, which I would rather not do, if it can be avoided.
Has anyone encountered this issue. Am I missing something here? I would appreciate your help.
