Good afternoon,
I hope someone can help me. I've been trying to troubleshoot my motor "no fire" issue. First thing I did was remove the black/yellow wire from the power pack. Still no spark.
Double checked the values of my stator get 750 ohms on brown/yellow with 180 volts with DVA and get 58 ohms on orange/black with 31 peak voltage. According to CDI that's good.
I'm moving now to the power pack but the only thing I see is the orange/black and orange wire which I'm not sure how to test. I tried with the peak voltage adapter but get nothing.
Any suggestion. Also wanted to know a part from the kill switch wire, is there something else in the key switch that can prevent firing?
