I recently purchased a 87 50 hp Johnson, it seems to run fine at the house. When I put it in the water it idles low and when taking off shuts off. Once I get it going and up to speed after a few mins, it starts losing speed and I have to keep priming the fuel line to keep it running at full speed. I have taken the carbs apart twice made sure everything is clean. It appears that they have taken the fuel pump off and just replaced it with a inline fuel filter. Could not having a fuel pump be part of the problem? I can't find very good picture online and was wondering if someone could post pictures off how the fuel pump is supposed to look on and what fuel lines go where? Any suggestions are much appreciated.
Thanks
Thanks
