I know that octane issues in this site had been debated long and passionately but i fail to find an specific answer to my dilemma. I have a Johnson 150 hp v6 VRO 1985 outboard that is running fine, just recently i got the Clymer service manual and it says quote:
1973-1985 135-235 HP-Lead-free regular,
lead-free premium, leaded regular, leaded
premium or gasohol with a pump posted octane
rating of 91 or higher. If a pump posted octane
rating of 88 is used, the maximum spark advance
must be reduced 4 ? except on 1983-1985 150 XP? and GrM
models. If a pump posted octane rating
of 86 is used, consult your local dealer as engine
modifications must be performed in addition to
reducing maximum spark advance.
Questions:
Does this means i've been messing my engine for the past year using 87 octane? (hey is running fine, so far)
Should i disregard this omc recommendation since it was done previous to the advent of TCW3 oil?
TCW3 oil actually make a difference?
Does gas differences on gas additive from 85 to 2013 will make a difference?
Should i'll spend big money and time taking this old but reliable engine to a certified dealer for the so call engine modifications to continue using cheaper 87 gas?
Thanks in for your responses
Questions:
