johnevin24
- May 10, 2013
- 18
Hi, I have a 1976 6 hp evinrude (6605a). The carburetor was flooding as soon as I pulled the motor over. I took the carb apart and cleaned it 4 times but still floods. I just rebuilt the carb with NEW CARB kit, set float etc. Now the thing will only run with the choke on. As soon as I go to take the choke off it quits running. I have also put another fuel pump on and still does the same thing. I checked all bolts etc and everything is tight. I cant figure this out,any suggestions? thank you. p.s. I also set the adjustment to 1-1/2 turns but even if I turn it in or out in small increments it still does the same thing.
