I have pulled carb off twice checked float level and drop. Replaced Fuel Pump. No go.
this motor sat for 6-7 years with no use, is clean as a whistle 120PSI on both cyl, great spark, fuel is making its way to the bowl, but it will not start unless I push the key in runs for a few seconds then just dies out. I have the float level with the carb body and drop is 1.5".
any advise on this would be helpful....FYI prior to carb rebuild fuel was just pouring out of the top of the carb
Thanks again guys. in advance!!!
