chead98
- Sep 11, 2009
- 82
Hi guys. Had the 16' Starcraft Aluminum with the 40hp Johnson boat out today for a test run. 1st major run since I purchased it and had it serviced. I posted a question the other day re: a no start issue but solved it. Now we have another issue.
So me and the wife and daughter were out cruising around for 20 minutes or so testing it out. It was running great. We decided we had enough and this test should be good fine for a future outing. We started to head back in and I opened her out. I could hardly hold on to the stering wheel as we were going so fast (not) Anyway, as we were heading back in at a nice speed, it cut out. I noticed gas coming from the carb.
Now this happened last week too on a short test run and I disconnected the fuel line, waited a while, started it up without the fuel lines connected and it ran again for 30 sec or so and reconnected the fuel lines to make it back to shore.
Today we tried it again but pretty much ran the battery dry from turning it over and over.
Can anyone explain why it starts to spit gas from the carburetor cut out after cruising for some time.
I`m sure if I go out now and try and start it it would run first turn of the key.
Thanks, Chris
Thanks, Chris
