The Famous Grouse
- Sep 26, 2008
- 291
I have a 1988 Johnson 15 HP. It has factory e-start in case that matters. Bought as a seriously neglected motor that hadn't been run in years. To get the motor running, I took the carb off and disassembled to clean using carb cleaner and compressed air. But I did not remove the "plugs" to clean under then as I did not have a new carb kit with replacement plugs. Bottom line is that I undestand that I did not completely clean the carb and there is potential here for issues.
After cleaning and returning the needle to the standard setting, I got the motor to run, throttle up, and idle, so at this point I was thinking I may have her up and running.
Now the last problem. Had it out on a boat for a test run yesterday. It started fine, idles fine, and runs at low speed all the way through WOT fine, including no bogging or stalling on a fairly sudden throttle up.
Now the problem. When running at higher speeds, I'd say greater than half throttle (15-20 MPH with a 14 foot Jonboat) for anywhere from 30 seconds to 2 minutes, and then throttling back to a lower speed (but not dumping it all the way to idle suddenly. Just doing as you would normally do to bring a boat off of plane when approaching a landing for example), the engine suddenly stalls and dies somewhere below half throttle.
Restarting is then very difficult. The engine acts as if it was flooded, but I'm not absolutely sure if it is flooding out, or dying of fuel starvation and then flooding after repeated cranking trying to restart.
Letting the engine sit for a minute or two will usually produce a restart, but choking and some extended cranking is required. When it restarts, I have to run it at highest neutral speed for a minute or so, or the engine will die if I try to throttle back to shifting RPM too quickly.
But once I can slow the engine down to get it in gear, it then runs fine again. Until I try to come down off of a throttle >about half, then the issue repeats.
Any ideas what could be causing this? What should I try? Suggestions and advice please.
Many thanks.
Grouse
Many thanks.
Grouse
