My Throttle Control Box ('81 OMC) shifts fine into and out of forward/neutral/reverse, however, the throttle lever on the control box must be advanced an additional couple inches before the throttle cable begins to move at the engine end. The fast idle lever has the same play.
I would like to remove this play if possible. Is there a way to adjust throttle play in the OMC control box of this vintage (or could cable wear account for this large amount of play) ?
