Hi all, I just bought this boat late last spring and it was sitting for some time. Over the winter I had the lower unit re-sealed and the carbs disassembled and cleaned, compression is 140psi on both cylinders.
O.K. my timing situation, the idle stop screw is cranked almost all the way in - it just didn't look right. I checked the timing pointer with the #1 cyl. at TDC and they line up fine. With the idle sitting against it's stop, the timing is something like 10 degrees after TDC. My manual calls for 3 degrees before TDC at idle. I've post a couple of pics with the engine set at 3 degrees.
I'm scratching my head - any ideas?
