maineiac5586
- Feb 14, 2009
- 641
I have a 2003 Johnson 25 hp 2 stroke with a stuck powerhead. I lowered the lower unit to make sure the problem wasn't in the lower unit. I have tried the product Engine Release two times following the directions exactly (the product actually worked on a NIssan 8 hp I had with siezed pistons. I put an impact gun on the crank pulley nut (as per the instructions included with the Engine Release product), the engine didn't budge. I actually wound up stripping the crank pulley nut in the process (crank threads still good). I don't know what happened to cause the siezure as I bought the motor this way. The previous owner said it was not related to a lack of oil but who knows. He said he stored it at the end of season last year and this is how he found it this year. This is a clean outboard with electric start and really worth fixing. I have been looking for a used powerhead to replace it but have not confirmed what year powerheads interchange. Does anyone have any idea where to go from here? I really want to keep this outboard and not resort to parting it out. When I first removed the head I found rust in the cylinders (it looks a little better now after having been soaked with the engine release product. I will welcome all ideas on where to go from here. thanks
