Hi. I?m new on the forum, And must congratulate you all.
I am from Argentina and I?m havimg problems with my Evinrude 115 from 1980.
The engine used to run good, but suddenly no matter if it?s cold or warm it stars causing trouble.
The engine starts always and sounds good, does not have battery problems. The sparks are almost new.
Example: I?m running at 4000 to 4500 rpm (max 5000 to 5200), and suddenly it starts to loose power. And at full throtle it only climbs to 3000 - 3200 rpm and it sounds as if it is running in 2 or 3 cilinders.
At that point I put the engine at 1000 - 1400 rpm for a while, and then give full throtle, and nothig for some times.
All of a sudden when the rpm are climbing to 3000 I feel like a booster on my back and the engine sound perfect again a the rpm climb to 5000 as if nothing happens!!!!!!!!!!!!
I don?t know what to do or where to start looking for the cause of the problem. Any ideas will help me to find a solution to the problem.
thank you,
Meteoro
ps: electrical diagram of my engine is welcome.
thank you,
Meteoro
