Took my lower drive off for maintenance today and somehow the shift rod must have been knocked in the process, as the L shaped shift detent broke in two. Provided I can get the broken piece out of the housing, does anyone know if i would have to disassemble the entire lower drive in order to replace it? The detent is number 15 in the attached schemetic. Thanks!
