mrnmrskyle
- Apr 8, 2013
- 56
okay, well i figured my not running correctly post would probably not be specific enough for this problem... my engine is a J140TXCDC 86 johnson 140. I am missing 2 jets on the port side carbs. the other side had different jets in it than the port side originally... so I look online at the parts catalogs and find that #13 (the bottom one on each carb) says it is a 28... originally it had 16's in the bottom and 20's in the tops... the #19 which is the top one says "port" 20 2 required so I have no clue here... my other side has 28's in the tops and 20's in the bottoms.... ideas?
