90johnson120
- Apr 15, 2013
- 3
Hi folks. New to the forum. I'm hoping for some insight. I have a 1990 120 Johnson with the VRO disconnected and running with 50:1 mix gas. The motor starts right up and runs with power but smokes excessively at idle. It was this way when I bought it. I have black oil/ carbonization dripping down the cowel from the exhaust, creating a slick in the water. I brought it to a mechanic and he did a compression test - passed with flying colors. Asked me if I was putting too much oil in the mix because he had to adjust the carbs - floats were loose. He also replaced the plugs. I bought a new external gas tank, started with fresh gas - same problem. If I put my hand in the exhaust it gets sprayed with fine oil droplets. Could this be a head gasket gone bad or is the problem in the carbs. Thanks
