New to iboats. First post. Overhalling lower unit. Directly under the waterpump impeller is a stainless plate. Under the plate is the Oil seal. Under the Oil seal is a collar that the seal sets on. Now here is where I am stumped. Directly under
the collar on my unit was a needle bearing, with about half tge needles gone. Directley under the bearing appears to be a
bushing. The OD of the bearing and the bushing appear to be larger than the ID of the collar. That would say to me that the bushing and the bearing need to come out through the bottom. My Diagram of the lower unit appears to show the
bushing on the top and the needle bearing directly under the bushing. Please advise. Thanks
