Hello,
I have a 1977 Johnson 200 HP (model 200TL77C) that I just rebuilt because one of the top pistons (port) was gaulded up in the cylinder and seized up. I have run it for about an hour or so on muffs at idle speed, and she runs great. I took it to the lake yesterday tom test. The engine runs fine in gear at idle speed. I got the boat up on plane for about 30 seconds at WOT, then she bogged down and shut off. When I tried to restart, the starter would not turn the engine over even though the battery was fully charged. So, I took it home and pulled the plugs to see if I could turn it over. Same result. So, I pulled the heads and discovered that one of the top pistons (opposite side this time-starboard) was starting to gauld and had seized in the cylinder. The port side also had a few aluminum scuffs. I was able to break it loose by turning the flywheel nut with a big wrench. Upon further inspection, I found that the small water passage hoses had melted to the outside of the cylinder wall ONLY on the top two cylinders. The rest were fine.
My question is: Do you think I have a problem with my thermostats? I figured that maybe they are stuck open, and since water enters at the top cylinder these are the coolest cylinders and it may be causing cold seizure. The added friction then heats the cylinder so much that the water passage tubes melt. Or could it possibly be a lean condition at high RPM from the top carburetor? The plugs looked OK- a little discolored. Tops of pistons also looked good except the one that seized- it was totally black on top.
All help is greatly appreciated. Thanks.
