Hello friends, i hope someone can help me, i have a motor evinrude intruder model 1996, 150 hp, works fine, kindle perfect, but to move from neutral to forward and want to accelerate, the engine dies
You need to do the linkage and synchronization with the leg in water and the prop under load. Adjusting idle on the "muffs" is incorrect. This is the most common cause of stalling when put in gear.
good morning friend, thanks for your response.
can you tell me how make it ?, have you some pictures or video, where can i see the parts ( " muffs " ) in my motor ?
