Starts fine, runs fine for 10 min then the alarm sounds. Still idles ok but when you throttle up it sputters up and down. If I let it sit off for five min. it starts and runs fine as long as I take off before alarm starts. Alarm does not go off if I plane off but as soon as I idle for 5 or 10 min. it starts again. If its an overheat alarm would that make it run as described and then run fine when it cools down? Or is it a vacuum alarm?
