davedublin
- Apr 18, 2013
- 12
Hi guys - I'm new to this forum and I would appreciate your expertise.
I have a Johnson 20 hp, mid- to late 60s. After many decades of faithful service, the impeller in the water pump spun on the key on the prop shaft, the pistons nipped up and I am doing a complete engine refurb.
I have a block from other engine that is serviceable, and I want to make sure all is OK before I proceed with other work. But I am looking at those pesky exhaust cover screws, some of which are well seized. To make matters worse, they are slotted screws, not the hex heads on the later models. From the look of some of the screw heads, the cover has probably never been off. I had a big fight getting all the bolts off the lower unit to engine block and I'm not looking forward to getting all these screws off.
In your experience, is it really necessary to remove the exhaust cover? I am only thinking to check for blockages, as I don't want it overheating in this area. If it flows water OK, would this be enough?
Dave
Dublin, Ireland
Dave
Dublin, Ireland
