JasonSchmuecker
- Apr 14, 2013
- 2
Hello, I have a '62 FDL-16 18 hp motor. I recently rebuilt the carb, and replaced all of the fuel lines. I was following the directions in this previous post, http://forums.iboats.com/engine-fre...sorted-carb-variations-joe-reeves-167352.html, and when adjusting the lower high speed needle valve, the motor never wanted to "die out" or "spit back," it raced to high rpms really quickly, which I then chose to shut down. I need help in adjusting these, as the sleeves that both needle valves sit in starting to loosen up.
