I have just recently purchased a 1964 Johnson 9.5, it was only running on one cylinder. I have since changed the coil pack and it is running pretty good need to adjust low idle, trying to figure out how to get it to idle at a low rpm. But today i took the boat out and fished for a couple of hours and started the motor a few times to get to different spots. Well the last time i started it up i noticed that it was running a little rough, so i pulled the cover off and noticed that there was water spraying inside the engine compartment. Not really sure where it is comming from (it was a little rough on the water) it looks like its coming from under the pull cord spool or the back side of motor, i have been searching and can't find anything about it. I have seen something about a water jacket gasket but it was on a evinrude motor. I really hope someone can help me out with this as i am a novice to boat motors. Thanks in advance Zac
