oldfarmall
- Jun 18, 2009
- 63
Hello-
Could someone tell me if the engine has to be split and taken apart to change the upper and lower crank bearings on a 1957 Johnson RDE-19 35hp?
Also, does any aftermarket company make the oil seal puller for the top crank seal? Or has someone done this without the tool. I am not to keen on using a screwdriver to pry it out, wooried aboutdamaging something else. Thanks in advance!
Are there any tricks to replacing the carbon seal on the bottom of the motor, or is it just straight forward. Do I just remove the snap ring and slide the whole works off, then install the new components and reinstall snap ring?
Jesse
Jesse
