1987 Evinrude Yachtwin 6hp Head Torque Please?
sashko1
Could someone tell me what the head bolt torque for my E6SLCUD motor is please?
raczekp1
Re: 1987 Evinrude Yachtwin 6hp Head Torque Please?
i torgue head bolts by hands just to feel proper force
sashko1
Can you describe what's "proper force" is please ? Last time I used this method I busted good threads on a vintage motor...
Ps - I normally use "proper force" when I deal with a woman;-) sorry I had to....
Rick.
Cylinder head screws 60 -80 INCH pounds. Start in the middle and keep going in a clockwise direction out to the ends. Flywheel 40 -45 foot pounds. Taken from an OMC service manual for a 1968 6HP. Best of luck. Rick.
sashko1
I think they changed the block significantly for 1987. My motor has only 6 head bolts and they are bigger in diameter.
Rick.
That is significant. Mine appears to have ten. Probably best to get a manual for your specific engine. Your head must be a lot thicker.
Rick.
nwcove
144-168 inch lbs. still "pinwheel" out from the bolts between the plugs, and torque in at least three stages. then recheck after a few runs.
nwcove
rick, your numbers are correct for 1979 and older 6 hp, but from 1982 the numbers changed. (flywheel nut went to 480-600 inch lbs.)
sashko1
Thank you good fellas a lot for your support!
