henson2205
- Apr 11, 2013
- 2
I have a 1995 30 HP Johnson. The engine idles perfectly. If I put it in reverse or neutral, I can go to full throttle with out any problems. When I place it in forward, I can throttle to about half before the engine goes sluggish. If I place my hand half way over the intake to the carb, it throttle back up but only to the same speed as half throttle.
When I turn the throttle all the way, it will run at full throttle like normal for a few seconds before bogging down.
Here are the things I have already done:
Rebuilt carb with carb kit w/float
Rebuilt the fuel pump
Replaced the spark plugs
Replaced the power pack
Replaced the ignition coils
Both spark plugs are firing. I already check to make sure the carb wasnt over opening.
Please help me! I cannot figure out why it will only maintain at half throttle but dies down at full throttle.
